ALIGN Agricultural Helicopter
Focus Shots
Specifications & Equipment |
Body Length1587mm
Body Height570mm
Body Width427mm
Main Rotor Length900mm
Main Rotor Diameter1986mm
Tail Rotor Diameter313mm
Empty WeightApprox. 13.7kg(w/6S 12000mAh Battery x 2)
Takeoff WeightApprox. 24kg (Filled with 10L containers)
900MX Brushless Motor450KV/4535
Max Output Power5100W/11000W(2sec)
Chemical Container15L
Maximum Working Speed8M/sec
Spray EfficiencySpray up to 0.48 acres per minute
(1 acres per = 4046 Square meters) Spray Operation Flight Time(Payload : 10L ; Flight Currency : 60A)Approx. 17min.(w/12000mAh Battery/900mm Blades)
Approx. 20.5min.(w/16000mAh Battery/900mm Blades) Flight Time Without Payload(Included spraying equipment / Currency : 30A)Approx. 20min.(w/12000mAh Battery/900mm Blades)
Approx. 25min.(w/16000mAh Battery/900mm Blades) Spray SystemAtomized particles
SF11002:136~177 Micron / SF11015:< 136 Micron |
AP2 Flight Control System |
Input VoltageDC 6-8.4V
Operating Current Consumption< 300mAh @ 6V
Operating Frequency180MHz
Operating Temperature-20°C ~ 65°C(-4°F ~ 149°F)
Hovering Precision (Depending on Satellite Status)Horizontal ±1m(3.28ft),Vertical ±0.5m(1.64ft)
Maximum Flight Speed8M/sec
Maximum Altitude Restriction300m(984ft) above the takeoff point
Maximum Angular SpeedAileron/Elevator 200°/sec, Rudder 400°/sec
Maximum Tilting Angle40°
Supports Helicopter ConfigurationsALIGN E1 / G1
Dimension43.8x35.5x20.4 mm
VTD1 1080 HD Digital Video Transmitter |
Working Frequency5~5.9Ghz
Way of TransmissionSDR Wireless Transmission Frame
Wide Transmission Distance1.5~2km
Emission Power200mw(23dBm)
Power ConsumptionTransmitter < 2.5W,Receiver < 2W
Latency< 40ms
Video Output1080P/720P HD Digital Video Transmission
Mobile Phone/TabletAndroid and Flight Controller OSD Display
Antenna5dB Circular Antenna
Dimension66x62x13mm
Weight41.8g
900MX Brushless Motor |
Input Voltage12S
Max Continuous Current115A/250A(2sec)
Stator Arms12
Magnet Poles10
Dimension6x56.7x112.5mm
Weight570g
Millimeter Wave Radar |
Emission Frequency24~24.20 Ghz
Emission Power(EIRP)13~24 dBm
Measurement Accuracy±0.02M
Update Rate50Hz
Range Resolution0.75M
Working Temperature-40℃~85℃
Dimension92x63x6mm(HxWxD)
Weight22g
P2 PCU Power Control Unit |
Input Voltage7.4V~12.6V
Operating Frequency168MHz
Operating Temperature-20°C~65°C(-4°F~149°F)
Dimension49.5x40.5x26.8mm
1080 DV Two-axis Gimbal |
Working Voltage5~12V
Image Output1080P 30fps
Lens Angle130°
ApertureF2.0
FeatureSupport Low Light Compensation, 3D/2D Dynamic Noise Reduction, Auto Exposure, Auto Focus, and Auto White Balance
Capable of Gimbal Control Angle0° ~ -90°
Dimension100.4x74x111.5mm
High Pressure Spraying System |
Pump Supply Voltage12~16V
Pump Power Consumption3A
Flow DetectingChemical Volume Detecting /Remaining Warning
Flow ControlSpray Calculator 0~5 L/min
Container Volume15L
Pump ControlSpray Amount Setting 0~5 L/min
Pump Max. Operating Pressure6.5 Bar
Obstacle Avoidance Radar System |
Transmission Frequency24GHz
Power Consumption400mW
Detection Range0.5~25m(Depend on target size and material)
Detection AngleHorizontal 34 degree / Vertical 34 degree
Effictive Flight ConditionFlight Altitude over 1.5m
Flight Speed lower than 5m/s
Start Safe Braking Distance6m
Safe Braking Distance2~3M
Approaching DirectionForward-looking
Equipment Required for Assembly |
Battery8" Tablet* Support Android V8.0 or better.
* Considering the best working efficiency, the specifications of the tablet are recommended as follows:
8” Tablet, 6 Core CPU, 3GB RAM, more than 32GB ROM storage space and support 5G Wi-Fi.
* The max. dimension of screen bracket is 240x169mm.
Tablet SuggestionsSamsung Galaxy Tab A /Model Type:SM-T385
Samsung Galaxy Tab A 8.0 /Model Type:T295 (LTE) Samsung Galaxy P200 Samsung Galaxy Tab A 10.1 /Model Type:SM-T510 Mi Band 4 ASUS ZenPad 3 8.0 /Model Type:Z581KL |
