Product
The new 600FL Flybarless Rotor Head System as well as 550 Main Shaft set
We’re glad to announce you the new 550FL & 600FL Flybarless Rotor Head System as well as 500 Main Shaft set. The new unit utilizes extreme low CG design, effectively reduces resistance during 3D maneuvers, increased flight responsiveness and precision.
In addition, the styling appearance harmony with red anodized and stainless color, bring out the high quality of helicopter.
A grand debut of Align M480 & M690 Multicopter!!
After times of researches and development, Align R&D team dedicated all of its technical expertise and experiences into the development of a brand new aerial photography platform, to give birth to the brand new:
Multicopter: M480 (4 rotors with span of 800mm)
                       M690 (6 rotors with span of 900mm)
3 Axis Brushless…
New Arrival !! T-REX 550L Dominator
http://shop.align.com.tw/product_info.php?products_id=5302
With a size that fall in-between large and small models, T-REX 550 features stability and agility which is the most popular model for pilots in all classes to practice. Now T-REX 550L Dominator inherit with all outstanding design concepts and much superior power supply that will guaranteed jaw dropping performance.
T-REX 550L firstly utilizes composite material integration technology on carbon side…
Gpro V1.2 Firmware and V1.2 Windows Interface Software Update!
Download: http://www.align.com.tw/Gpro/CH/
Gpro Firmware
Gpro V1.2 Update Feature
Fixed Gpro LED light instruction – Head lock – Green Light / Non-head lock – Red Light.
Fixed fail to open error in Nitro Governor Setup.
Reminder
Gpro firmware V1.2 must be used with interface software V1.2; suggest to start by downloading Gpro Interface Software V1.2.
Interface software 1.2
Added bounce out window when adjusting the Nitro Governor…
700FL Flybarless Rotor Head System New Arrival!
http://shop.align.com.tw/product_info.php?products_id=5297
●The 700FL Flybarless Rotor Head System utilizes extreme low CG design, effectively reduces resistance during 3D maneuvers, increased flight responsiveness and precision. In addition, the styling appearance harmony with red anodized and stainless color, bring out the high quality of helicopter.
●Must with 700FL Main Shaft Set(H70H003XXW)or(H70035)、700 Newly Main Rotor Holder(HN7116)、Feathering Shaft(HN7025)。…
500E Speed Fuselage New Release!!!
HF5017T 500E Speed Fuselage – Yellow & Blue
http://shop.align.com.tw/product_info.php?products_id=5268
HF5018T 500E Speed Fuselage – Blue & White
http://shop.align.com.tw/product_info.php?products_id=5298
HF5019T 500E Speed Fuselage – Red & White
http://shop.align.com.tw/product_info.php?products_id=5299
HF5020T 500E Speed Fuselage – Red & Yellow
http://shop.align.com.tw/product_info.php?products_id=5300
Check out these exciting new fuselage for the Align Trex 500E Pro and Pro DFC. Following the design concept of the Trex 700E Speed Fuselages, we now present the new 500E Speed…
Gpro Binding & Setup video
Gpro Binding & Setup via PC and iOS/Android APP
PC
Gpro Spektrum binding
Video
Gpro Hardware Connection
Video
Gpro Parameter Setup
Video
iOS/Android APP Setup
iOS
Video
Android APP
Video…
New Release T-REX 150 DFC Super Combo!
http://shop.align.com.tw/product_info.php?products_id=5282&language=en
Align’s smallest and most petite 3D helicopter T-Rex 150 DFC, carries the same superior pedigree and design concept that originated from the successful T-Rex line of helicopters. Featuring strong power, superior flight control stability, and equipped with high end components, far exceeding any other helicopters currently on the market.
Twin brushless motor design, paired with 2s 7.4v 250mah battery, creating power…
New Release Align Gpro and Bluetooth device!
Gpro:
http://shop.align.com.tw/product_info.php?products_id=5289&language=en
Bluetooth Device:
http://shop.align.com.tw/product_info.php?products_id=5290&language=en
ALIGN new multifunctional Gpro flybarless system with active CPU, processing 20 times faster than previous generation. The freshly new software structure improves system compensation, bring GPro up with precise and agile response, and also keep up-to-date flying performance than ever.The most important is that utilizes with latest iOS and Android APP can be easily and directly adjusted through mobile…
