Brand New G800F Aerial Gimbal System Combo Release!
  • Brand New G800F Aerial Gimbal System Combo Release!
    http://shop.align.com.tw/product_info.php?products_id=4932&language=en
    Align G800F gimbal is an upgrade product catered specifically for the needs of aerial photography. The included GS850 gimbal controller features high power computing capability, and various control modes to precisely lock into the shooting object, as well as meet the needs of various other aerial photography needs, allowing optimal imagery to be obtained easily. This system must be used in conjunction with Align’s APS gyro and T-Rex 800E. Fiberglass composite material matched with high strength aluminum alloy to form the gimbal backbone, featuring high precision, high stability, capable of high payload, and is able to sustain hard landing of helicopter. When paired with 540 degrees DS815 servo and belt transmission design, the gimbal is capable of wider turning angles with higher precision.
    Unique gimbal support assembly design, with aesthetic pleasing clean look, featuring high precision and slop free and makes the camera lens maintain at the same angle in flight.
    Shock absorbing dampners designed specifically for Align G800F gimbal system, posses superior vibration dampening effect, and various spring tensions can be used according to payload.
    GS850 CONTROLLER :
    ●New in GS850 gimbal controller are PAN/ROLL/TILT gain adjustments. Targeted for carrying different camera payloads, the 3 gain adjustment dials on the controller can be used to achieve faster and more precise gimbal corrections, elevating the already excellent performance of G800 gimbal, resulting in more stable imagery.
    ●The gimbal control system consist of 5 working modes: 3 axis automatic correction, 2 axis auto neutralization, 3 axis auto neutralization, 3 axis neutral, manual, and rescue mode. Camera zoom and shutter control function can also be controlled through the GS850 controller. Only a few steps is needed to complete the simple setup process. The controller is also capable of connecting with Spektrum/JR satellites, as well as Futaba S-BUS standard.
    High rigid gimbal bottom plate and gimbal camera tray supporting pole that featuring high precision, high stability, capable of high payload, and is able to sustain hard landing of helicopter
    Utilizes with 540 degrees DS815 servo and belt transmission design, the gimbal is capable of wider turning angles with higher precision
    Focus Shot4(New GS850 Controller support with 5 operating modes and various functions as usual, further equipped with built-in PAN, ROLL and TILT gain dials enable immediate attitude compensating reaction based on different weight of photograph equipment. Featuring much higher degree of control precision)
    Shock absorbing dampers designed specifically for Align G800F gimbal system, and various spring tensions can be used according to payload
