ALIGN G1 Agricultural Helicopter Released
  • ALIGN G1 Agricultural Helicopter Released
    ALIGN G1 Intelligent and Precision Chemical Dispersion Helicopter with Engine Power 60cc two-stroke engine made in Japan. The power is a 60cc Two-stroke Engine, and this high-performance Japanese engine is recognized as the leader in agricultural applications where reliability and availability are the most critical attributes. Specially equipped with the three-blade rotor head provide superior flight stability with low CG design allow to reduce flying resistance but bring better buoyancy and more precision and rigidity response.
    Align G1 is equipped with two 5.5KG chemical containers. It’s capable of switching the containers in 5 seconds. Also, there are two types of fan-shaped nozzles can be used for adjusting output to different plants.
    Adopted with sonar altimeter to detect the terrain height so the helicopter can adjust to maintain the same distance from the plants to provide a uniform spray across all crops. It has built-in dual sensor positioning module, GPS + Glonass or GPS + COMPASS system. Moreover, it’s compatible with P2 PCU (power control unit) allow to distribute and integrate the power supply safely. Equipped with extremely bright LED search headlight, to improve night exploration with better visibility and improved safe night operation.
    Align AP2 intelligent flight controller supports multiple flight modes (such as Attitude/GPS/Intelligent/Manual), Auto Return Home and Rescue Return Home…etc. Moreover, in our highly integrated ground station, the automated mapping function will compute the best spraying route for you or allow you to map preferred pattern, which can achieve advanced spray capacity for safe, efficient and convenient way to deliver superior crop protection.
    7
    14
    15
    16
    17
    19
    20
    21
    22
    23
    24
    25
    26
