T-REX 800E PRO DFC Super Combo
The T-REX 800E PRO DFC is an 800 class flagship designed specifically for 3D flights. The CCPM direct connect servo design, coupled with DFC rotor head assembly, results in fast, precise, and more direct control reaction. The frame material integration technology is utilized on the landing gears and vertical tail fin, creating a unique look not only making the T-REX 800E PRO DFC stand out, but also resulting in an innovative design that encompasses structure rigidity along with beautiful aesthetics.
Nothing was spared in the electronics components of the kit: The mighty power of the 850MX(490KV) motor paired with Castle Edge HV 160 speed controller for unparalleled power output; The new CNC machined aluminum cased BL800H brushless high voltage cyclic servos paired with BL850H rudder servo not only exhibited top of the line servo aesthetics, but also combine heat sink function and best performance in the market segment.
The T-REX 800E PRO DFC can be described as the current top of the line flagship representing Align’s superior product line. Based on the pedigree of pure 3D flight, the newest design concept with absolute top of the line equipment, along with superior aesthetics and attractive lines, the T-REX 800E PRO DFC will definitely elevate the adrenaline in your blood!
▼Equipped with the low CG DFC rotor head, exhibits exhilarating 3D performance and unimaginable flight speed.
▼850MX inherit from the previous 800MXs feature, high efficiency, superior power, excellent torque, low current draw and low temperature. It’s capable of maintaining much more consistent torque and head speed through continuous 3D maneuvers, which is particularly special design for 3D flights.
▼New style swash anti-rotation guide with embedded anti-wear material, effectively minimize the wear between swashplate long ball and guide.
▼The shapely Reinforcement plate and brace are special design for T-REX 800E, effectively increase the torsional strength of main frame, under extreme 3D maneuver, you can strongly feel its solid reinforcement from its structure, thenew CNC machined aluminum electroplate red, is particular arranged in groups of 850MX motor, subtly bring the T-REX 800 stylish and metal beauty.
▼Equipped with new high strength cnc m1 helical main gear and tail drive bevel gear assembly, featuring reinforced overall gear structure and increased gear thickness, effectively improves gear’s anti torsion ability to prevent gear from deforming under extreme power,reducing gear wear and power loss.
▼Utilizes composite carbon material integration technique on frame structure for CCPM servos. Brand new CCPM direct servo linkage design.
▼Innovative composite of fiber material for landing gear, unique stylish shape, functional intensity and visual beauty are both innovative design.
▼Using competitive material and special imbedded technology for vertical tail, enhanced its structural strength and boutique texture efficiently, vivacious color providing excellent visibility.
▼High quality new tail gearbox design, combined with new dual point mounted tail pitch control assembly to minimize slops and increase rudder control precision.
▼Utilizes newly developed, highest spec and superior anti-wear material to increase the overall strength and durability for torque tube drive gear. Effectively minimize gear striping and crash damage.
Standard equipment
●Castle EDGE HV 160 Brushless ESC
●850MX Brushless Motor(490KV)
●BL850H High Voltage Brushless Servo
●BL800H High Voltage Brushless Servo x 3
●3GX Flybarless system
