T-REX700E PRO DFC Introduction!
  • T-REX700E PRO DFC Introduction!
    In continuation of the superior pedigree of T-Rex 700E DFC, combined with the latest innovation in power system and numerous top of the line performance upgrades, Align introduces the latest 2013 flagship model: T-Rex 700E PRO DFC.T-REX700E PRO DFC includes the highly sought safter 800MX 520KV motor as standard equiment, specially anodized in burgundy to exhibit the exclusivity of this flagship model. The newly designed 700 3G main blades and 105mm tail blades are catered specifically towards hard core 3D flying, increasing agility while maintaining stability, and increased rigidity to improve anti-torsion characteristics, finished with a fresh new coat of graphic design. In addition, T-REX700E PRO DFC includes numerous upgrades such as DFC rotor head system, new style swashplate anti-rotation guide, hardened main gear, new tail drive gear assembly, dual hinged tail control assembly, etc. The fiberglass canopy also took on a brand new look with new shape and new graphics, with even lower wind resistance, giving the T-REX700E PRO DFC a refreshing feel.
    On the electronics front, only the top of the line brushless servos(BL615H、BL655H) were used. Combined with dramatically improved 3GX V4.0, not only will it satisfy the complex maneuvers of the experts, it also creates an excellent stable and secure feel for the beginners. The brand new T-REX700E PRO DFC will introduce you to a completely different experience.
    The 700 DFC flybarless rotor head system utilizes extreme low CG design, effectively reduces resistance during flight, increased flight responsiveness and precision.
    800MX features high efficiency, superior power, excellent torque, low current draw and low temperature; it’s capable of maintaining consistent torque and head speed through continuous 3D maneuvers.
    New style swash anti-rotation guide with embedded anti-wear material, effectively minimize the wear between swashplate long ball and guide.
    Equipped with brand new 700 3G carbonfiber main blades designed specifically for extreme 3D flights, featuring agility and stability, and new graphics paint scheme. The increased blade rigidity improves anti torsion characteristic during flight, and the new airfoil minimizes turbulence near the blade tip, reducing blade noise and power loss.
    Brand new tail blade designed to sustain optimal tail locking performance under high head speed and extreme flight conditions.
    Utilizes composite carbon material integration technique on frame structure for CCPM servos. Brand new CCPM direct servo linkage design.
    Equipped with new high strength cnc m1 helical main gear and tail drive bevel gear assembly, featuring reinforced overall gear structure and increased gear thickness, effectively improves gear’s anti torsion ability to prevent gear from deforming under extreme power,reducing gear wear and power loss.
    High quality new tail gearbox design, combined with new dual point mounted tail pitch control assembly to minimize slops and increase rudder control precision.
    New style wrap around airbrushed fiberglass canopy, with aerodynamic form to reduce wind resistance. 4 point anti-vibration mounts for quick install and removal.
    DS615 & DS655 digital servos
    Castle ICE2 HV 120 Brushless ESC
    Brand new redesigned 3GX represents a new generation of multi function flybarless system. The dramatically improved performance will create immediate impact on any enthusiasts.
