T-REX 550E PRO DFC new release!
Super Combo:
http://shop.align.com.tw/product_info.php?products_id=5081&language=en
Combo:
http://shop.align.com.tw/product_info.php?products_id=5087&language=en
Brand new T-Rex 550E PRO DFC incorporates all new design elements, focusing specifically on upgrading the power with a 700 class motor, the 730MX (850KV). With a size that fall in-between large and small models, this brand new T-REX 550E PRO DFC features stability and agility, with superior power output that will guaranteed jaw dropping performance.
T-REX 550E PRO DFC is equipped with latest designs such as: DFC main rotor system, new 112T CNC helical main gear, new style tail drive assembly, new style tail control system, etc. The most talked about feature is the newly developed 730MX (850KV) motor, a motor normally found in 700 class helicopter but over spec for 550 class. Enthusiasts can clearly feel the dramatic increase in power and torque, while taking advantage of its higher efficiency, lower current and temperature benefits. In addition, the newly designed 2mm thick 3K carbon side plates not only enables the installation of wider 730MX (850kv) motor, they also simplify the structure, while maintaining high rigidity and easy maintenance.
The clean atheistic exterior, ergonomic design, and superior control feel; all are reasons for enthusiasts not to miss this value packed T-REX 550E PRO DFC!
Equipped with the low CG DFC rotor head, exhibits exhilarating 3D performance and unimaginable flight speed.
New DFC CCPM Swashplate and new metal body mount to increase body rigidity and added gyro placement location.
New 2mm 3K carbon fiber side frame for simple yet rigid frame construction, not only for easy assembly and maintenance, but also allowing capable of 730MX(850KV) motor to increase fight power.
Integrated swash anti-rotation guide and gyro mounting platform.
Equipped with new high strength cnc m1 helical main gear and tail drive bevel gear assembly, featuring reinforced overall gear structure and increased gear thickness, effectively improves gear’s anti torsion ability to prevent gear from deforming under extreme power, reducing gear wear and power loss.
Power upgrade to 730MX(850KV) motor, the feel as If a turbo charger was added to the helicopter, capable of high efficiency, low current and low temperature, with dramatic 700 class flight performance in 550 class helicopter.
Rear mounted rudder servo mount & carbon fiber gyro mount.
Equipped T-REX 600 class tail boom set, supporting with 600mm main blade and increase tail stability.
Brand new tail blade designed to sustain optimal tail locking performance under high head speed and extreme flight conditions.
High quality new tail gearbox design, combined with new dual point mounted tail pitch control assembly to minimize slops and increase rudder control precision.
