T-REX 250 PLUS DFC (BTF) Release!
  • T-REX 250 PLUS DFC (BTF) Release!
    RH25E03XW       T-REX 250 PLUS DFC BTF
    http://shop.align.com.tw/product_info.php?products_id=4971&language=en
    Align another special response to the countless requests from marketplace and available a simple version of T-REX 250 PLUS DFC,base on Align 250 class beginner entry version: T-REX 250 PLUS, designed with Align T6 2.4G and newly released 3GX MRS flybarless system, as same as RTF version, this package was assembled and tuned at the factory, allowing the pilot to bypass assembly and adjustment process. All you need to do is simply bind the Align T6 or Futaba S-FHSS 2.4G or Spektrum DSM2/DSMX or JR DSM2 satellite and transmitter than fly it.
    The helicopter utilizes DFC rotor head assembly, paired with 3GX MRS flybarless system optimized for T-REX 250 PLUS DFC flight characteristics. Without any adjustment or tuning, this combo will provide optimal stability suitable for pilots of all levels.
    With the addition of the brand new 3GX MRS, the T-REX 250 PLUS DFC pushes past the performance limitation of flybar helicopter, improving both stability and 3D performance, while maintaining a down to earth price level.
    ▼The 250 DFC flybarless rotor head system utilizes extreme low CG design, effectively reduces resistance during flight, increased flight responsiveness and precision.
    ▼Brand new 250DFC Metal Swashplate.
    ▼Brand new battery mount with integrated ESC mount.
    ▼Main frame applied with new Insert-Modeling allow to fix servos into helicopter directly without nut washer.
    ▼New anti-rotation guide.
    ▼New style gyro mount with integrated rudder servo mount for centralized CG, advantageous to 3D flying.
    ▼Utilizes dual point attachment design for zero play and higher precision control feel.
    ▼High efficiency shaft tail drive system, effectively increase rudder performance and decrease power loss.
    ▼3GX MRS’s was designed with goals of simple, convenient, light, and ease of adjustment. With the embedded brand new Futaba S-FHSS 2.4Ghz system/JR DSM2 and Spektrum DSM2/DSMX ,the 3GX MRS is more than just a flybarless system; it simplifies installation on small/micro sized helicopters since no receiver is needed.
    ▼DS415M Digital servo
    ▼DS425M Digital servo
    ▼RCE-BL15P Brushless ESC
