6S1P 22.2V 1250mAh/45C Battery
http://shop.align.com.tw/product_info.php?products_id=5110&language=en
●Suitable for T-REX 450 6S system with 460MX Brushless Motor(1800KV)(HML46M01).
●This Li-poly battery is using series/balancing design, features high efficient and high discharge, use a inspection machine to match packs, suitable for TREX 450 series(450MX Brushless Motor 1800KV).
●Max Continuous Discharge: 45C. Normal operating temperature is approx. 40-65°C(within 80% of rated discharge). Max. temperature: 80°C.
●Recommend to discharge the battery within 80% of rated discharge, keep 95% capacity when over 100 cycles, keep 90% capacity when over 150 cycles.(The cycle life and efficiency will reduce due to high current, high temperature and over-discharge)
●Output:22.2V1250mAh 27.8Wh(6S1P)
●Dimension:105x34x28mm
●Weight:210g
