New Arrival T-REX 700E PRO DFC KIT
http://shop.align.com.tw/product_info.php?products_id=5128&language=en
In continuation of the superior pedigree of T-Rex 700E DFC, combined with the latest innovation in power system and numerous top of the line performance upgrades, Align introduces the latest 2013 flagship model: T-Rex 700E PRO DFC.
T-REX700E PRO DFC includes the highly sought safter 800MX 520KV motor as standard equiment. The newly designed 700 3G main blades and 105mm tail blades are catered specifically towards hard core 3D flying, increasing agility while maintaining stability, and increased rigidity to improve anti-torsion characteristics, finished with a fresh new coat of graphic design. In addition, T-REX700E PRO DFC includes numerous upgrades such as DFC rotor head system, new style swashplate anti-rotation guide, hardened main gear, new tail drive gear assembly, dual hinged tail control assembly, etc. The fiberglass canopy also took on a brand new look with new shape and new graphics, with even lower wind resistance, giving the T-REX700E PRO DFC a refreshing feel.
The 700 DFC flybarless rotor head system utilizes extreme low CG design, effectively reduces resistance during flight, increased flight responsiveness and precision.
New style swash anti-rotation guide with embedded anti-wear material, effectively minimize the wear between swashplate long ball and guide.
800MX features high efficiency, superior power, excellent torque, low current draw and low temperature; it’s capable of maintaining consistent torque and head speed through continuous 3D maneuvers.
Utilizes composite carbon material integration technique on frame structure for CCPM servos. Brand new CCPM direct servo linkage design.
Equipped with new high strength cnc m1 helical main gear and tail drive bevel gear assembly, featuring reinforced overall gear structure and increased gear thickness, effectively improves gear’s anti torsion ability to prevent gear from deforming under extreme power,reducing gear wear and power loss.
Equipped with brand new 700 3G carbonfiber main blades designed specifically for extreme 3D flights, featuring agility and stability, and new graphics paint scheme. The increased blade rigidity improves anti torsion characteristic during flight, and the new airfoil minimizes turbulence near the blade tip, reducing blade noise and power loss.
High quality new tail gearbox design, combined with new dual point mounted tail pitch control assembly to minimize slops and increase rudder control precision.
Brand new tail blade designed to sustain optimal tail locking performance under high head speed and extreme flight conditions.
Standard equipment
●700 3G Carbon Fiber Blades x 1set
●105mm 3K Carbon Fiber Tail Blades x 1set
●800MX Brushless Motor(520KV) x 1
