MR25/MR25P 1830 DV-BOX Assembly Notice!
  • MR25/MR25P 1830 DV-BOX Assembly Notice!
    We’re pleased to inform you about MR25/MR25P DV-BOX. The DV-BOX is specialized for DV PCB protection that is superb light weight, easy to assemble and also can protect main board from some crash damages as well. Therefore, we’ll include the special DV-BOX into each MR25/MR25P cases for customers’ preference. Of course, we’ll also catch up for your MR25/MR25P which already dispatched, you should get free Box in your following shipments, don’t worry! So make sure to contact with your sales staff for next MR25/MR25P delivery arrangement soon for free DV-BOX.
    ▼Temperately remove DV camera ribbon cable apart from DV main board and camera lens.Remove the latch apart to the front.Then gently remove DV camera ribbon cable.
    ▼Gently remove 2-pin and 3-pin connectors.
    ▼Before assembly DV-BOX, fix three buttons at appointed position.
    ▼Take DV double-sided tape from spare parts bag, and stick it onto DV-box and DV camera mount.
    ▼Connect DV camera ribbon cable back, and press the latch in position. Then connect 2-pin and 3-pin connectors back to finish assembling. Install DV-box and buttons, then tighten four round headed cross self-tapping screws (T1.4 x 4mm).
