Product
T-REX 450L DOMINATOR 3S
http://shop.align.com.tw/product_info.php?products_id=5095&language=en
The internationally popular T-Rex 450 has long been a trend setting helicopter, every enthusiasts probably has owned at least one. It is the ideal model for beginners as well as experts practicing advanced maneuvers. Now the T-Rex 450 evolution continues, as Align drops another shocker into the market; with even more innovative designed incorporated, the brand new…
T-REX 550E New Release!
Brand new T-Rex 550E PRO DFC incorporates all new design elements, focusing specifically on upgrading the power with a 700 class motor, the 730MX (850KV). With a size that fall in-between large and small models, this brand new T-REX 550E PRO DFC features stability and agility, with superior power output that will guaranteed jaw dropping performance.
T-REX 550E PRO DFC is…
600E PRO Performance Booster (Video)
A power upgrade system designed specifically to bump up the power output of T-Rex 600E Pro by 30% by upgrading the motor from 600MX motor (3300w/5500w) to 750MX/530KV motor (4400w/7260w). The feel as if a turbo charger was added to the helicopter, with dramatic increase of motor torque output, and near bulletproof governing speed of the rotor, while maintaining power…
Metal Shapely Reinforcement Plate And Brace Assembly Release!
http://shop.align.com.tw/product_info.php?products_id=5021
Brand new CNC metal reinforcement plate and brace effectively increase the torsion stength of main frame, under extreme 3D maneuver, you can strongly feel its solid reinforcement from its structure. Its attractive machined aluminum electroplate red, is particular arranged in groups of 850MX motor, subtly bring up the helicopter stylish and metal beauty!
Suitable for T-REX 700E/800E.
Brand New G800F Aerial Gimbal System Combo Release!
http://shop.align.com.tw/product_info.php?products_id=4932&language=en
Align G800F gimbal is an upgrade product catered specifically for the needs of aerial photography. The included GS850 gimbal controller features high power computing capability, and various control modes to precisely lock into the shooting object, as well as meet the needs of various other aerial photography needs, allowing optimal imagery to be obtained easily. This system must be used…
The Best Servo Release!
BL800H High Voltage Brushless Servo
http://shop.align.com.tw/product_info.php?products_id=5025&language=en
Instruction:
●Utilizes brushless motor design for fast speed, high efficiency. And with the absence of brush wear, the longevity of servo is greatly increased.
●Supports 8.4v high voltage to provide optimal speed and torque performance of the brushless servo.
●Designed specifically for helicopters, with highest specifications on the market: 0.058sec/60°ultra fast speed and 23kg-cm monstrous torque, allowing helicopter to…
T-REX 800E PRO DFC Super Combo
The T-REX 800E PRO DFC is an 800 class flagship designed specifically for 3D flights. The CCPM direct connect servo design, coupled with DFC rotor head assembly, results in fast, precise, and more direct control reaction. The frame material integration technology is utilized on the landing gears and vertical tail fin, creating a unique look not only making the T-REX…
Brand New DS615S Digital Servo release!
●Special and unique low profile design, beside helicopters, also suitable for RC cars and airplanes.
●Using high efficiency coreless motor, higher performance superiority, increased output torque, faster reaction time, resulting in higher holding power on swashplate, providing precise control feel. Obviously its high performance is suitable for RC cars and airplanes.
●Silicone-insulated magnet wire, providing a high-end texture and a durable protection…
Brand New GS850 gimbal controller!
●New in GS850 gimbal controller are PAN/ROLL/TILT gain adjustments. Targeted for carrying different camera payloads, the 3 gain adjustment dials on the controller can be used to achieve faster and more precise gimbal corrections, elevating the already excellent performance of G800 gimbal, resulting in more stable imagery.
●The gimbal control system consist of 5 working modes: 3 axis automatic correction, 2…
