Product
New Products Arrival-RCM-BL4213 Brushless Motor
http://shop.align.com.tw/product_info.php?products_id=5401
HML4213M01 RCM-BL4213 Brushless Motor
ALIGN’s brand new, multicopter specific BL4213 370KV brushless motor inherits ALIGN’s core motor technology, featuring high torque, high efficiency, low power draw, and low temperature. The superior performance enable 20 minutes flight on empty M480 using a single 6S 22.2V 5200mAh battery, and…
New Products Arrival!!Multicopter 24 Carbon Tube 345/M480 Motor Mounts(R)-Black/M480 Upper Carbon Plate Damper
Multicopter 24 Carbon Tube 345 & M480 Motor Mounts(R)-Blackis & M480 Upper Carbon Plate Damper are available, please contact with our worldwide distributor for purchasing!
http://shop.align.com.tw/advanced_search_result.php?keywords=M480012&x=0&y=0
M480012XXW
http://shop.align.com.tw/product_info.php?products_id=5429
M480014XAW
http://shop.align.com.tw/advanced_search_result.php?keywords=M480030&x=0&y=0
M480030XXW
New Products Arrival-7 Inch Carbon Main Rotor
7 Inch Carbon Main Rotor is available, please contact with our worldwide distributor for purchasing!
http://www.align.com.tw/distributors-en/
MD0700A
http://shop.align.com.tw/product_info.php?products_id=5462
Light weight and highly rigid all carbon fiber main rotors are also available which features even higher flight efficiency and longer flight duration, while providing faster and more precise flight response.…
ALIGN PCU V1.1 is available now! Free to upgrade…
PCU Power Control System
http://www.align.com.tw/download/pcu/
Press to download
V1.1 Update Feature
Fix few cases of retract to make it more functional effectively.
Reminder
1. Before system updating, please make sure to remove PCU wire connection from gimbal, OSD+FPV video transmitter and APS-M controller.
2.Need to use PCU Update Connector to update.
PCU Firmware Update Instruction
http://www.align.com.tw/ManuaLib/update/PCU%20Firmware%20Update%20Instruction.pdf…
New Arrival-G3 Gimbal Extension Mounting Plate!
We are pleased to announce you the new Gimbal spare parts!
GG3011XXT G3-GH Extension Lower Mounting Plate
GG3012XXT G3-5D Extension Lower Mounting Plate
GG3013XXT G3 Extension Upper Mounting Plate
http://shop.align.com.tw/advanced_search_result.php?keywords=gg301&x=0&y=0
Suitable for G3-GH/G3-5D gimbal compatible with SLR-LIKE cameras and/or cameras with lighter weight or with short lens. Strongly enhance the attachment and correction of gimbal to reach and superb video stability.
G3 Gimbal and Camera CG setting-Video Sharing
Following we are going to share you how the correct CG setting will affect the shooting. If the CG is not adjusted correctly, it will cause camera jitter and damage the films quality.
Let’s see the video to know the real effects!
Video
Reminder:
Before center point adjustment, make sure to keep gimbal mount bracket and gimbal mount carbon tube in…
The tips for M480/M690 standard receivers!
If you use devo10 with rx1002 to fly M480.
The standard receiver can only control 7 channel.
However, the Intelligent Flight was set on CH8, so it cannot be controlled, nor Gimbal.
But, now you can use SBE-1 which was released by Futaba to change the standard receiver signal to S.BUS version.
It can control whole function of M480 including CH9 and CH10 to…
New Arrival: ALIGN “PCU Update Connector” HEBPCU02 !
PCU USB Update Connector is mainly designed for  updating the ALIGN PCU Power Control Unit.
Through connecting with PC interface, customers and pilots can update their Power Control Unit (PCU) system at ease.
HEBPCU02
PCU Update Connector…
OSD+FPV Program Update Instruction
Align update the OSD+FPV Program V1.1 to be compatible with more CCD cameras currently on the market.
Please go to below link to download the OSD+FPV program to desktop.
http://www.align.com.tw/download/osd/
Press to Download
V1.1 Update feature:
Wider compatibility with more CCD cameras currently on the market.
Notice:
1. Prior to performing update, disconnect the cable between APSM and PCU.
2. Most of CCD camera is …
