New Released!! Lower Carbon Plate Set/Lower Fiberglass Plate Set
●Suitable for M690L.
●Brand new lower main frame upgrade for M690L with retract moving 45mm forward to prevent against body dip to the front.
●Enlarge the retract width to 71mm while the original width is 56mm only. It allowa bigger capacity battery to be used for M690L, such as 6S 22.2 16000mAh. Battery size similar to 65mm*90mm*190mm are all compatible with the…
