The effects of vibration on gimbal filming quality
  • The effects of vibration on gimbal filming quality
    If propellers are too loose or too tight, there will be imbalance while they spin, causing vibration of the frame, and might have high frequency jello in resulting video. It may also cause the scenario that no matter how you tune the gains, you are unable to achieve smooth video.
    Through below video we will explain you some examples and the result of improper propellers assembly. Also the video can allow you to understand how important propellers installation is for multicopters electronic devices life service and gimbal stability.
    If you have jello effect, vibration or difficulty on parameter adjustment, please follow below video for correct propeller installation, which can effectively solve jello effect during video shooting.
    The test video is the default value settings of G2/G3 gimbal. G3-GH gimbal apply with yellow dampers* 8pcs and black dampers* 4pcs.
    Please check the video as below:
