Canon 5D Test Flight with yellow damper
  • Canon 5D Test Flight with yellow damper
    Gimbal: G3-5D – Canon 5D
    Camera Weight: 1324g
    Align Damper: Yellow damper*8pcs / Black damper*4pcs
    Test Flight 1:
    Parameter:
    Refer to adjustment reference document, parameter setting are listed as below:.
    Raw – Test Flight Video:
    Test Flight 2:
    After first test flight, you may find out there are vibration in the test flight video. Due to Canon 5D is much heavier than other cameras, our pilot lower the P gain of Roll & Tilt to 75 & 65, also keep Tilt gain lower.
    Parameter:
    Pilot Feedback:
    1. Parameter adjustment:
    Refer to G3 adjustment reference information, pilot set up his parameter and test the G3 gimbal accordingly.
    Due to different camera weight, pilot adjust the gain carefully based on actual situation, lower Tilt P Gain and keep Power and D Gain as higher as possible. Then the result is very good.
    2. Gimbal CG:
    Before adjust the parameter value, make sure to mount and set the gimbal at perfect suitable CG position base on manual instruction.
    3. APS-M Setting
    As we announce before, pilot set his APS-M Gain Setting as below:
    Aileron: 20%~25%
    Elevator: 20%~25%
    Rudder: 50%~55%
