News
Brand New 450 Feathering Shaft Set release!
Brand new design for 450 Feathering Shaft, both ends of shaft increased thickness from 3mm to 4mm, so its whole external diameter is equal in 4mm thick, plus 700 class of robust fixation between Main Rotor Bearing and Thrust Bearing which can be effectively enhance strength of main rotor system. In addition, adopted M2.5x6mm screws also redouble its intensity to…
H800 Cameral Helmet
http://shop.align.com.tw/product_info.php?products_id=4969
Designed specifically for the G800 gimbal, this unique ABS constructed gimbal sphere features bright yellow color for excellent visibility, high durability and impact resistant, offering superior protection for camera equipment. Whenadded to T-Rex 800E aerial photography ship, this G800 gimbal sphere will incura mere 500g of additional weight. The front, back and bottom of sphere isdesigned for quick disassembly, simplifying…
700E PRO DFC Anti Rotation Bracket Release!
●Use for T-REX 700E DFC / 800E PRO DFC.
●New style swash anti-rotation guide with embedded anti-wear material, effectively minimize the wear between swashplate long ball and guide.…
Brand New 850MX Brushless Motor Release
●To meet the power and torque requirements of enthusiasts, the high output 850MX motor was born in Align’s R&D lab. With dramatic increase in torque and power output, capable of 5100 watts continuous power output and 11000 watts of burst power!
●Inherit from the previous 800MXs feature, high efficiency, superior power, excellent torque, low current draw and low temperature. It’s capable…
T-REX700E PRO DFC Introduction!
In continuation of the superior pedigree of T-Rex 700E DFC, combined with the latest innovation in power system and numerous top of the line performance upgrades, Align introduces the latest 2013 flagship model: T-Rex 700E PRO DFC.T-REX700E PRO DFC includes the highly sought safter 800MX 520KV motor as standard equiment, specially anodized in burgundy to exhibit the exclusivity of this…
New Arrival 800E Aerial Fuselage!
http://shop.align.com.tw/product_info.php?products_id=4938
●Special designed for T-REX 800E platform for aerial photography, fiberglass material, exterior rich sense of technology, features both light weight and high strength characteristics.
●Bright yellow color can effectively enhance identification in the sky, conducive to aerial photographic operation.
●Suitable for T-REX 800E Helicopter series.
●Quick disassembly design, as long as a few screws can fast install and remove for convenient to maintenance.
New Listing APS LITE!!
http://shop.align.com.tw/product_info.php?products_id=4933&language=en
Instructions:
APS Lite Gyro is an electronic flight augmentation device, and can only function when used with Align’s 3GX flybarless system. With APS Lite Gyro installed, the helicopter will have the ability to self stabilize, hold position as well as altitude, and even autonomous way point flights as well as return home. It is the perfect tool for flight training, as…
